Copy value from multiple linked issues to parent issue
arpit doshi September 16, 2015
I have one issues linked to multiple issues having different values in same field. I am looking for combining the values of multiple linked field into one and copy to the parent issue.
Any solution ??
Nick
I think your question is not clear enough.
You have to specify when the values are to be copied/combined. This could be whenever one of the values changes, by choosing a menu item, etc. You have options and what to implement depends on your requirement/decision.
After that you will need to write some code to copy/combine the linked values. You can get the linked issues for the "original" issue or the subtasks and then "combine" the values and set the value in the "original" issue.
arpit doshi October 2, 2015
I want to copy values either on workflow transition or schedule a daily script in bamboo to update copy/update field values. Putting some script in workflow transition is a better option.
Let's build A Rovo Agent 🤖
Save your spot
