Copy value from one custom field to another in the same issue
Dan27
I run this code on Script Listener and it supposed to copy the value from one custom field to another:
I try with update value and it didnt work too
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder;
import com.atlassian.jira.issue.util.IssueChangeHolder;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.security.groups.GroupManager;
import com.atlassian.jira.issue.IssueImpl;
import com.atlassian.jira.issue.IssueInputParameters
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def issue = event.issue as MutableIssue
def issueManager = ComponentAccessor.getIssueManager();
log.warn issue.getIssueType().name
//Condition if QVR
if (issue.getIssueType().name=='QVR')
log.warn 2
//Get Assigned QA Team value
def Team = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Assigned QA Team"));
def val = Team.toString();
CustomField wbl = customFieldManager.getCustomFieldObjectByName("WBL Agile Team");
def value = ComponentAccessor.optionsManager.getAllOptions()?.find { it.toString() == 'Unassigned Team' };
log.warn value;
if (val==null)
issue.setCustomFieldValue(wbl, value)
else
issue.setCustomFieldValue(wbl, val)
Tarun Sapra
Hello @Dan27
You are using issue.setCustomFieldValue
But in the docs it's not the recommended way
void setCustomFieldValue(CustomField customField,
                         Object value)
Sets a custom field value on this Issue Object, but does not write it to the database. This is highly misleading.
To actually set a custom field value, use OrderableField.updateIssue(com.atlassian.jira.issue.fields.layout.field.FieldLayoutItem, MutableIssue, java.util.Map)
Parameters:
Dan27
Hi @Tarun Sapra , thanks for the quick answer,
I try the code with update Value too, and it return an error :
//Condition if QVR
log.warn 2
log.warn value;
if (val==null)
IssueChangeHolder changeHolder = new DefaultIssueChangeHolder();
//issue.setCustomFieldValue(wbl, value)
wbl.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(wbl), value), changeHolder);
else
//issue.setCustomFieldValue(wbl, val)
wbl.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(wbl), val), changeHolder);
issue.store();
Tarun Sapra
What's the type of your custom field?
Also, could oyu please use code macro to paste your code as that makes it more easily readable.
Dan27
them both single choice.
Tarun Sapra
June 14, 2018 edited
Use this and if it doesn't work, please share the exact error which you are getting
if (issue.getIssueType().name=='QVR') {
log.warn 2
def team = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Assigned QA Team"));
def value = ComponentAccessor.optionsManager.getAllOptions()?.find { it.getValue() == 'Unassigned Team' };
log.warn value;
if (!team) {
else {
wbl.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(wbl), team), changeHolder);
Dan27
Work!!!!! Thanks a lot!!!!! @Tarun Sapra
Tarun Sapra
Glad to know @Dan27 that it worked! :)
Please accept/upvote the answer so that others are helped as well! Thanks.
Mark Markov
June 14, 2018
Hello @Dan27
Please see this article on how to update jira fields via api.
https://community.atlassian.com/t5/Agile-articles/Three-ways-to-update-an-issue-in-Jira-Java-Api/ba-p/736585
And remember that method
not saving changes in History of issue.
