  • Community
  • Q&A
  • Jira
  • Questions
  • Copy value from one custom filed to another when the value of the first custom field is changed
Nadica Gaber
Hi All,
We need to copy the value from CF 1 to CF 2 as soon as the CF 1 value is changed.  Adding a post function for copying the values does not meet our needs. Can this be done with a script?
Nadica
7 votes
Johnson Wang
Hey @Nadica Gaber,
I agree that the POST function doesn't really give you the ideal solution you're looking for.
This can definitely be done with a script, and I'd recommend an add-on like Power Scripts.
We've put together a quick tutorial video showing exactly how to copy a field value from one field to another as soon as the first field's value is changed. You can even copy and paste the SIL script to see how it works.
Hope this helps!
Johnson
Alexey Matveev
November 16, 2017
Which plugin do you have to write a script? If you have Adaptivist Scriptrunner, you could write a listener. The listener would catch the update issue event and checked if the required field changed. If it ischanged, then you could change the other field.
Read more information about listeners here:
https://scriptrunner.adaptavist.com/5.0.0/jira/listeners.html#_custom_listeners
But you are not limited to Adaptivist scriptrunner, there are must be other plugins with such functionality
Mandia December 26, 2018
Hi @Alexey Matveev
I have the similar need as @Nadica Gaber. But I want to implement that if parent's Due date field has changed the open subtask's due date change to blank by using SIL listeners
Could you please give me a demo code?
Mandia
Alexey Matveev
December 27, 2018
Hi @Mandia
It would be better if you asked a new question and mention me in this new question. But anyway here is the solution :)
JFieldChange [] changes = lastIssueChanges(key);
boolean flag = false;
for(number i = 0; i < size(changes); i++) {
  if (changes[i].field == "CF1") {
    flag = true;
if (flag) {
  #{CF2} = #{CF1;
Mandia December 27, 2018
Thanks for replying me !
Here is my new question :https://community.atlassian.com/t5/Jira-Software-questions/When-Parent-Task-Due-date-changed-open-sub-task-due-date-change/qaq-p/969271#M38530
I saw your code, I want to implement when the parent task due date changed then the open sub-task 's due date auto change to blank. not copy value
Mandia
Alexey Matveev
December 27, 2018
You are most welcome! Done :)
