Copy values when bug is marked as duplicate
Chris K.
When Bug A gets resolved as a duplicate of Bug B, I want to copy certain field values from Bug A to Bug B. I'm trying to figure out the best way to do this. The only thing I came up with is to create a post-function script on any transition that could set the resolution and:
1) check to see if the resolution was duplicate
2) look at Bug A's linked issues and find the duplicate issue ID
3) grab the field values we want from Bug A
4) copy them over to Bug B
Is that the best way to do this?
Jonny Carter
August 25, 2016
Yup, that's how I'd do it. Sharing an implementation would certainly be cool of you. smile
Ravi Sagar _Sparxsys_
August 24, 2016
Chris,
The steps looks fine. Do share your implementation, that will also help others. In case an event is not triggered by workflow transition you can also use Listener that doesn't rely on a post function.
Ravi
