Good morning,
I have a structure where I defined a custom column (Formula) for all the issues in this structure.
Is it possible to assign the value calculated in the formula to each issue type, so when I open the single issue (not in the structure, but stand alone) I can see the calculated value?
I don't know if it is clear, let me know if you need more information.
Amedeo
Hello @Amedeo ,
If I have it right, you want to see the calculated value, from Structure, on the Jira issue details screen.
From the Tags you added, it appears you are currently on Server. If this is the case, you can use an Attribute to Issue Field Effector to write the formula value to your issues.
Hope this helps!
Best,
David
