Correlation between Field screen and Workflow status
Samuele Pretini September 28, 2014
My problem is:
I want that a custom field "percentage of progress" is editable only when a issue is in Executon status. In all other statuses that field must only be visible, but not modifiable.
How can I do it?
Nic Brough -Adaptavist-
September 28, 2014
Remove the field from the "edit" screen, and create if you need to.  Put it on a new screen.  Create a workflow transition from "execution" back to "execution" and use the new screen as the "transition screen".  You can then limit who can use it as well as stop it being edited unless in execution.
Or use the behaviours/scripting plugin.
Help us plant more trees
