Hello
I need help :)
On the Jira server is the next folder
whose volume is 31 gb.
What data is this?
Can you tell me if I need this data if I can delete it?
hey @keti burjanadze ,
It appears to be your xml backups that are scheduled to run each day. Some of them apparently were corrupted. (might be some more info in the txt file)
https://confluence.atlassian.com/adminjiraserver/automating-jira-application-backups-938847675.html
The older data can surely be removed as I'm assuming you also have SQL/System backups?
The main thing here is
