Hey Nikolai
I think you have much more easier way to do it.
Check Customer Case addon for JIRA.
Regards.
Yes you can link them directly to a JSD form (eg: https://myorg.atlassian.net/servicedesk/customer/portal/1/create/2) but your user will need to register / login first.
Another popular approach is to use JIRA issue collector (works for both JSD and JIRA Software projects): https://confluence.atlassian.com/display/AdminJIRACloud/Using+the+issue+collector
