Couldn't connect to the Jira instance
Troy B. Stauffer January 29, 2019
When I try using the Outlook 365 plugin to Jira and enter the jira url, i get the error message
Our jira url contains a port so i am not sure if that is the issue or not but there isn't much to go on
Francesc_Arbó
January 30, 2019
Hi @Troy B. Stauffer,
could you please show us the error message?
Thank you in advance.
Troy B. Stauffer January 30, 2019
Francesc_Arbó
January 30, 2019
I don't know this app. I guess it's an app for Outlook and not for Jira. Reading their documentation it's not clear how to connect it.
Hope anyone know how it works.
Troy B. Stauffer February 1, 2019
I uninstalled it because it doesn't work anyhow.  sorry to trouble you.  I just thought it was something you supported.
consider this solved :)
I've considered the same problem. Worked after changing the header for like 5 min. After uninstall and reinstall it does not work anyways. Maybe it's because of reverse proxy or SSO
Register now
