Count values of a custom text field
Cem Tuğrul October 14, 2024
I have a custom text field as "A" and the values (enterable) like;
a,
b,
c,
d,
So this means I have 4 values  for my "A" so how can I create a computable field as "B" that equals =4
Dick
Günaidin, @Cem Tuğrul
By having A as a text field, you can receive a multitude of values.
It also means, you need to define how you want to discern the difference in values:
For example:
  • Is "a" the same as "A" ?   (upper/lower case)
  • Is "ü" the same as "u" ?   (diacritic markings)
  • Is "a" the same as "a "     (trailing space)
To avoid having to answer (and program!) these questions, can you give a bit more insight as to why you want to count the amount of similar field entries?
Best regards,
Dick
By voting for helpful posts and marking answers to your question, you're helping people with similar questions find a solution more quickly. Sharing is caring applies to knowledge as well :)
Hello Dick,
Thanks for your reply. In my create issue there is a custom field type as text lets say "X"
and the values have to entered like as ;
a,
b,
1,
3,
PT134,
means values seperating by comma(,) According to these counted values I am gonna create sub_task. The example as given above You can see there are 5 values entered because the values seperating by (,) so this means I have to create 5 sub-tasks as ;
a
b
1
3
PT134
that's why I need calculated values from my text custom field X
Dick
Hi @Cem Tuğrul
There's a different way to approach your problem (a way without counting).
you can use string manipulations on the value stored in your custom field. As you can search for a designated character in a string such as the mandatory comma, you can split the string into chunks of string that are in fact the names of the subtasks that need to be created.
Atlassian's page on Smart values & String manipulations
substringbefore would be handy in your case
Hope this helps you getting your stories straight (pun intended)
Dick
Learn more
