Hi All,
Hope you are doing well,
I recently add some plugins in my Jira, but suddenly my Create button has gone in the navbar. where has it gone :) How can I bring it back?
Check that you are logged in, and have "create issue" permission in at least one project.
First of all I would try from a other browser and while using incognito mode. See if you can see the create button. In addition, kindly cross check that your other colleagues have/have not visibility of the create button as well. If the problem persists, try to remove the apps you installed and see if that resolves the problem.
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
