In the current documentation for Create Group in the JIRA Rest API:
https://docs.atlassian.com/jira/REST/latest/#api/2/group-createGroup
I can't seem to find what to put in the payload or parameters for the POST command to /rest/api/2/group.
I was wondering if I could get some help.
Try this in your post method:
{"name": "GroupName"}
I test with REST API Browser and it work fine. I normally use the groovy script to do stuff with the API.
Here is my example:
import static groovyx.net.http.ContentType.* import groovyx.net.http.HTTPBuilder import groovy.sql.Sql import static groovyx.net.http.Method.* // JIRA Authorized user (Local) JiraUsrName = "" // JIRA Admin username JiraPsw = "" // JIRA Admin password // JIRA API servers def JIRAServer = "yourserver/jira" // TheMan/jira (Do not put http) println "" + System.getProperty("line.separator") println "===============================" println "Starting on: ${JIRAServer} Server" println "===============================" // Global Parameters def httpAdd // Obj for the HTTPBuilder def TestAddGroup = [] // Test Add Group def Count = 0 // Counter for loop // Example data TestAddGroup.add("ManTestAAA") TestAddGroup.add("ManTestBBB") TestAddGroup.add("ManTestCCC") // JIRA Rest API httpAdd = new HTTPBuilder("http://${JIRAServer}/rest/api/2/group") httpAdd.headers['Authorization'] = 'Basic ' + "${JiraUsrName}:${JiraPsw}".getBytes('iso-8859-1').encodeBase64() // If found any groups if ( TestAddGroup.size() ){ // Add JIRA user to the tempo-approval group through the Rest API println "" println "=== :Groups are Being Added: ===" while( Count < TestAddGroup.size() ){ httpAdd.request(POST, JSON){ // Parse JSON data body = [ name: "'" + TestAddGroup[Count] + "'" ] response.success = { resp -> println "Success! ${resp.status} : Added ${TestAddGroup[Count]}" Count++ } response.failure = { resp -> if (resp.status == 400) { println "Request failed with status ${resp.status} : User requested an empty group name or group already exists" } else if (resp.status == 401) { println "Request failed with status ${resp.status} : The current jira user is not authenticated" } else if (resp.status == 403) { println "Request failed with status ${resp.status} : The current user does not have administrator permissions" } else if (resp.status == 500) { println "Request failed with status ${resp.status} : Operation is not permitted or error occurs while creating the group" } else { println "Error : Error code is not match or jira may down" } Count = TestAddGroup.size() + 1 } } } } else { // No user found to add println "=== :No group to add: ===" }
Thanks so much! :)
