Create Issue - sort projects list alpha?
Mark Haller
Hi there
Is it possible now, or planned in a later release, to ALPHA SORT the list of projects when creating a new Issue from the "Create Issue" dropdown? I've got 30 projects and growing rapidly and it's getting hard to use!
Mark
Beth Schaefermann
February 24, 2012
What version are you running? I am running JIRA 4.4.4. The way i see my list sorted is ordered in two groups. The top ten are under a heading that reads "Recent Projects," which I assume is in the order of my last access. The rest fall under a heading that reads "All Projects." Those are alphabetized. Those that are in the Recent Projects list are repeated in the alphabetized All Projects list. I probably have about fifty in my list.
Mark Haller
Hi Beth ... well, thanks for the reply ... I'm running JIRA 5 now (woohoo, upgrade 2 days ago) ... and I see the same as you - Recent Projects in order accessed and All Projects, alpha-sorted.
Hmm, so what was I seeing before and why!?!? How random! Consider this closed unless someone else wants to re-open as they have the same problem! :-)
Renjith Pillai
October 13, 2012
Sridhar,
The list of projects that are shown are the ones in which you have create permission for issues. If you need to get rid of projects appearing for everyone, ensure that the right project permissions are in place.
ShridharS August 28, 2012
Hi There,
Even i am facing the same issues, can any body please give me the solution how to HIDE or REMOVE the list of projects under create a issues link, OR else is there any alternate issue to avoid the problem.
Please reply to my query
Shridhar
Hi There,
Shridhar
