We're using Jira v5.1.2 and we try to create new Jira issue via rest api.
we run :
cmd = "curl.exe -D- -u user:pass -X POST --data @data_to_send.json -H 'Content-Type: application/json' 'User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:20.0) Gecko/20100101 Firefox/20.0' http://outJiraSite/rest/api/2/issue/"
subprocess.check_call(cmd) data_to_send.json: { "fields" : { "project": { "key": "CT" }, "summary": "testing", "assignee": { "name": 'team' }, "issuetype": { "name": "Task" }, "description": "Testing automatic create Jira Issue \n", } }
and get :
curl: (6) Could not resolve host: (nil); Host not found HTTP/1.1 415 Unsupported Media Type Date: Tue, 10 Sep 2013 07:38:46 GMT Server: Apache-Coyote/1.1 X-AREQUESTID: 38x583x1 X-Seraph-LoginReason: OK X-ASESSIONID: 6n27hs X-AUSERNAME: -------- Content-Type: text/html;charset=utf-8 Content-Length: 1117 Set-Cookie: JSESSIONID=----------------------------------; Path=/; HttpOnly Set-Cookie: atlassian.xsrf.token=BBOO-X31J-0L8A-OSLQ|---------------------|lin; Path=/ <html><head><title>Apache Tomcat/6.0.32 - Error report</title><style><!--H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}A.name {color : black;}HR {color : #525D76;}--></style> </head><body><h1>HTTP Status 415 - Unsupported Media Type</h1><HR size="1" noshade="noshade"><p><b>type</b> Status report</p><p><b>message</b> <u>Unsupported Media Type</u></p><p><b>description</b> <u>The server refused this request because the request entity is in a format not supported by the requested resource for the requested method (Unsupported Media Type).</u></p><HR size="1" noshade="noshade"><h3>Apache Tomcat/6.0.32</h3></body></html>
Can you please help and advice?
Is there any other way to create Jira issue via rest api?
Thanks!!
Shani
to add watchers then try with this rest api
I'm not sure what is wrong on your json file, but try the following:
{ "fields": { "project": { "key": "AWD" }, "summary": "Issue created via REST.", "description": "bla bla bla goes here", "issuetype": { "name": "Task" } } }
And also reduce your call to: curl -D- -u user:pass -X POST --data @data.json -H 'Content-Type: application/json' http://localhost:8080/rest/api/2/issue/
Please help Please help!!
I'm try to serch Jira issue , my URL is "http://MyJira.com/rest/api/2/search?jql=summary~'DOA_DigitalZoom_Smooth failed on C16'"
I run this using json.loads but it can't find this issue although this issue existing!!!!
Can you please help? what wrong in my url?
Thanks you!
I solved a similar problem by URL-encoding the query string.
(Try posting additional problems as new question. There's no incentive to look into questions that are already marked as answered.)
I've one more question please, is there any way to add watchers to ticket via rest api?
I can’t find it here - https://developer.atlassian.com/display/JIRADEV/JIRA+REST+API+Example+-+Create+Issue
Thank you!
Shani
Thank you all. I had several mistakes in my fields request…
Finally, I didn’t use Curl and I used urllib2.Request…and it work!
I’ve one more question please; I like to search jira ticket by summary.
My url is : http://host.com/rest/api/2/search?jql=summary~[x][y][Unstable]- TestGroup/Test failed on 16.
Since my url contain spaces, it can’t find issue.
Do you know how can I overpower this problem?
Thank you very much!
Shani
generally what is the URL using to login to jira i mean something like
Jira.atlassian.com:8080 or Jira.atlassian.com:8080/jira?
Take a look at Python Client for JIRA
https://marketplace.atlassian.com/plugins/com.atlassian.jira.jira-python-rest
With this client you will be able to very easily connect and create JIRA issues.
Full documentation:
http://jira-python.readthedocs.org/en/latest/
I hope that will help.
Best Regards,
Mirek
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
