I have oauth application links with Confluence incoming impersonated by a user who can create pages in the relevant space.
This is the URL where I end up when I try to create the KB article:
plugins/createcontent/draft-createpage.action?draftId=1212514
The page you were trying to reach could not be found. This could be because: The page does not exist. The page exists, but you do not have permission to view it.
The application links work otherwise (self service, issue links etc.).
JIRA is version 6.4.2, Confluence 5.7.4
I have no idea what could be causing this other than some weird application link problem.
Any ideas what to do?
Hi Seb,
As the App links are properly working here, a page not found generally could be related to redirections or some address being added, not compatible with the App links URL. For that, check for the following:
Hope it helps you!
Giuliano T.
Confluence/Crowd Support
Register now
