Create Selectable Dropdown Checklist
Atul Vig January 17, 2019
I would like to create a selectable dropdown that has a customized checklist for each dropdown item.
Arun_Thundyill_Saseendran
January 17, 2019
Hi @Atul Vig
If the available custom fields do not suit you, you should be looking into a plugin that could give you this feature.
If you could explain the problem statement in detail, people here will be able to help better.
Arun
Hi Arun,
For example if i have a drop down menu with Employees, Remote, Contractor as the items. If i choose Employee, i want to have a checklist for employees, if i choose remote, i want a differetn checklist for remote, etc.
Jakub Hanak
January 18, 2019
Hello @Atul Vig,
For example ScriptRunner addon can help you achieve this. We use this feature for JSD.
Best regards,
Jakub
Register today
