Create a Back Button in Jira
Daniel_90 August 14, 2015
Hi there,
I created a button (AUI button) in our JIRA plugin. Here is the HTML snippet:
<button  id="help-back-button" class="aui-button">Back</button>
 Now I want to give this button the behavior to execute the "back operation". I want to step one webpage back (namely going back to the JIRA Dashboard). I tried some Javascript code, referencing with the button's ID. However, nothing happened...could you tell me how to resolve this?
Thanks a lot in advance,
Daniel
Christophe Promé
Something like this should do the trick :
<button onClick="history.back()">click me</button>
If you don't want to write javascript directly in your HTML, you can also attach a listener and call the history.back() function from your javascript callback.
More about the history api.
Christophe
Hi Christophe, thanks for answering.
I tried to solve it with javascript callback according to the history api. Here is the code
AJS.$(
"#help-back-button").click(function() {
	history.back();
 Unfortunately, nothing happens. So I have two questions:  1) Is this code wrong? 2) When I have Javascript code updated, does JIRA suddenly realize this or am I obliged to use fastdev or the command atlas-run again in order to make the changes applicable?
Thanks for answering,
Daniel
Christophe Promé
The code looks fine. Is your button attached to the DOM when you create the listener ? Do you have any error in the console ? Add a 'debugger' statement in your code and try step by step debugging within your browser. Usually, it is enough to reload the page to get the newest javascript.
Daniel_90 August 17, 2015
Thanks Christophe for answering. The button is not attached to the DOM, didn't know this is required. What is the code I have to insert in the DOM? In the console I don't have errors. There is just nothing happening when clicking the button. Well, the only thing what's happening is a refresh of the current page. However, with the button I'd like to go one page back. Thanks for your help conserning the POM code. Daniel
Christophe Promé
There are thousands of ways to insert a button in the DOM Depends on your plugin implementation....
michael_ngangom
August 14, 2015
This is the general idea:
<button onclick="goBack()">Back</button>
<script>
function goBack() {
    window.history.back();
</script>
Hope this helps!
Register now
