Create a SubTask via JMWE "Create/Clone Issues Post Function"
Ozan Topkaya July 17, 2023
Hi all
By doing a transition, I want to get several issues from project A, into project B under a specific issue as a subtask (sub-test). (Issue link not needed) Unfortunately, I am not getting further. Does anyone have a solution for me. Thanks for your interest.
David Fischer
July 17, 2023
Hi @Ozan Topkaya
in your post-creation script, there's a type: you have
${issue.getAsString("APV")}
which in not a valid Groovy syntax, you need
(the ${} syntax is only valid within Groovy string constants and Groovy templates)
Ozan Topkaya July 18, 2023
[SWREL-214] Release 2023_R5.0 2 - JIRA Software - INT_2023-07-18_09-05-00.pngHello David
Thank you for the information. Now I am able to create Subtasks.
Still I can't manage to pull the field contents from the source issues. It creates as many tickets as JQL outputs in the script but all without summary, APV and APV Stl. fields. How can I build the connection between main tickets which are in other Project and new subtasks in
in shown project?
Goal
I want to copy/create all those issues:
project = SWINV AND status in (Aktualisierung, Installiert) AND Plattform-Entscheid in ('CSS Desktop') AND apv = 'p3839'
in project SWREL under one current ticket as a subtask.
David Fischer
July 18, 2023
Hi @Ozan Topkaya
Each issue returned by the JQL search (which, by the way, you could simplify using JMWE's jqlSearch global function) is available through the it global variable.
So to copy the Summary of each issue returned by the JQL search to each new issue, you can add the Summary field, select "Set field value to Groovy Expression" and use this value:
it.get("summary")
and repeat the same for other fields you want to copy.
Ozan Topkaya July 21, 2023
Hello David
Thank you very much for your help. Now it is working.
Arbeitsablaufübergang aktualisieren Create _ Clone issue(s) (JMWE app) Function _2023-07-17_16-36-41.pngArbeitsablaufübergang aktualisieren Create _ Clone issue(s) (JMWE app) Function _2023-07-17_16-37-35.pngFEHLER IM ARBEITSABLAUF - JIRA Software - INT_2023-07-17_16-06-04.png
