Create a filter for "not updated within X" but exclude comments made by "Automation for Jira"
Anthony Polakos
May 14, 2019 edited
I'm trying to create a filter to show issues that have not been updated (commented) in a certain amount of time.
The problem is I also have automation set up to remind my users to update their issues via a comment.
This causes any filter I create to show that issues have in fact been updated because of the Automation user commenting on them.
So, what I'd like is to be able to create a filter that shows me tickets that have not been updated in at least 5 days, but don't include comments made by the Automation user.  (Automation for Jira)
I currently have my filter set up to show issues that have not been updated in the past 5 days.... but the Automation comments are also set up on a 5 day schedule, so it makes this filter pretty much empty, even though my (lazy) users have not updated the issue in over 5 days:
project = BUILD AND resolution = Unresolved AND NOT updatedDate >= -5d ORDER BY status DESC, lastViewed DESC
I came up with this, but it does not work either because it does not look at comments:
project = BUILD AND resolution = Unresolved AND NOT updatedDate >= -5d AND (Not status changed BY addon_com.codebarrel.addons.automation)
Thanks much for any help you can provide!
John McKiernan
Hey Anthony,
this is a tricky, if not impossible, one to get around with JQL acting as a filter.
I don't know if this would suit your business needs but what you could do is - in your automation rule, you could send emails to your users rather than commenting on the issue. This would solve the problem.
Hopefully, that helps
John
Anthony Polakos
Thanks John. I came to the same conclusion. I’m going to be changing to emails.  Thanks for your input.
Anthony Polakos
May 14, 2019 edited
oops double post.
