Hi everyone,
As for the enviroment i'm using Jira Software and the only plugin im using is ScriptRunner.
My aim is to program a post-fucntion such as in the moment i transicionate an issue to "in progress" a sub-task with the same fields is created. Also, during the transition I pick up a comment that has to be in both Task and Sub-Task.
I'm using one of the build-in scripts of ScriptRunner "Create a sub-task"
Also I added this code
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.comments.Comment
import com.atlassian.jira.issue.comments.CommentManager
import com.atlassian.jira.user.*
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def commentManager = ComponentAccessor.getCommentManager()
def comment = commentManager.getLastComment(sourceIssue)
commentManager.create(issue,currentUser,comment.getBody(),true)
But all I get is this message
org.ofbiz.core.entity.GenericTransactionException: Commit failed, rollback previously requested by nested transaction.
And inside the log this one :
2018-09-26 16:18:21,949 ERROR [workflow.ScriptWorkflowFunction]: ************************************************************************************* 2018-09-26 16:18:21,950 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: COM-56, actionId: 11, file: null java.lang.IllegalArgumentException: eq(null) is not allowed. Use isNull() instead at com.querydsl.core.types.dsl.SimpleExpression.eq(SimpleExpression.java:127) at com.atlassian.jira.issue.comments.DefaultCommentManager.lambda$create$0(DefaultCommentManager.java:263) at com.atlassian.jira.database.DefaultQueryDslAccessor.lambda$execute$1(DefaultQueryDslAccessor.java:74) at com.atlassian.jira.database.DatabaseAccessorImpl.runInTransaction(DatabaseAccessorImpl.java:110) at com.atlassian.jira.database.DefaultQueryDslAccessor.execute(DefaultQueryDslAccessor.java:73) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:258) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:227) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:217) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:201) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:190) at com.atlassian.jira.issue.comments.DefaultCommentManager.create(DefaultCommentManager.java:179) at com.atlassian.jira.issue.comments.CommentManager$create$3.call(Unknown Source) at Script5.run(Script5.groovy:12)
I figured out the proble is with the "issue" variable used on commentManager.create, but I don't understand why?
Any Idea?
Thanks :D
Hi Xavier,
I was not able to fix this quickly but what I did is writing the comment to the description of the created sub-task and copying it in its create postfunction to a new comment using JSU (of course after the create issue postfunction). What I could imagine here is that the subtask issue is not fully created at the time these additional actions are executed and the commentManager can't add comments to a yet uncreated issue...
Best regards
Christoph
