Create an issue, when creating an issue
Steve Sweales
June 17, 2014
Is it possible to automatically create an issue (in project B) when I create an issue in project A?
Danilo Conrad
June 17, 2014
Hi Steve,
This is not possible by default in JIRA, but you may try the plugin below:
Danilo
Bob Swift
June 17, 2014
Vijay Khacharia
June 17, 2014
I used the Script runner plugin for similar task. On create transition, I add a post-function that creates another issue.
Here is the sample code.
def projectName = "Dev Tools"       // Name of project you want to create the issue in
projectMgr = ComponentManager.getInstance().getProjectManager()
def wasIndexing = ImportUtils.indexIssues
ImportUtils.indexIssues = true
issueObject = issueFactory.getIssue()
issueObject.setProject(projectMgr.getProjectByName(projectName))
issueObject.setIssueTypeId("1") // normal subtask
// set subtask attributes
issueObject.setFixVersions(issue.getFixVersions())
issueObject.setAffectedVersions(issue.getAffectedVersions())
issueObject.setPriority(issue.getPriority())
issueObject.setSummary(issue.summary)
issueObject.setDescription(issue.getDescription())
issueObject.setReporter(issue.getReporter())
issueObject.setAssignee(issue.getAssignee())
// Create subtask
Map params = new HashMap();
params.put("issue", issueObject);
Issue StreamReq = issueManager.createIssueObject(authenticationContext.getUser().getName(), params)
Nadir MEZIANI
June 17, 2014
You can do it using one of the scripting utilities plugin like script runner or jjupin, jss.. or develop you own plugin.
Look to this links its can help you and give you more ideas.
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunnerhttps://marketplace.atlassian.com/plugins/com.quisapps.jira.jsshttps://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.jjupin
