×As mentioned in this ticket -
https://jira.atlassian.com/browse/JRASERVER-25808
The workaround for using transactions with ActiveObjects in Jira (and what Atlassian is doing) would be to manually start a transaction:
import com.atlassian.jira.transaction.Transaction; import com.atlassian.jira.transaction.Txn; Transaction txn = Txn.begin(); try { ... txn.commit(); ... } finally { txn.finallyRollbackIfNotCommitted(); }
begin is declared as
/** * Represents the ability to peform a database transaction in JIRA. * * @since v4.4.1 */ public interface TransactionSupport { /** * This begins a new transaction if one is not already running for this thread. * <p> * It will be a NoOp if a transaction is already running and in this case a call to {@link * Transaction#commit()} will also be a NoOp. The outer caller is then reponsible * for the ultimate commit or rollback. * <p> * It will also be a NoOp if a transaction support in JIRA is turned off. * * @return a {@link Transaction} context object that you can called commit or rollback on * @throws TransactionRuntimeException if the transaction can not be established at all */ Transaction begin() throws TransactionRuntimeException; }
So to interact with Transaction interface, I need it reference the appropriate maven dependency. Where can I get the dependency? I am developing the plugin for JIRA 7.3.0.
Asked this question at wrong place, moved this to Atlassian developer community.
Heres the link if anyone wants -
