Hello
I am trying to create a custom report using groovy scriptrunner.
For e.g. I'd like to
1. Create a new report form with some inputs (I assume I can create such form as new script runner REST endpoint)
2. Place this form in a Project->Reports section (e.g. like standard reports - "average age report", "created vs resolved issues", ...) or as new gadget
3. Run report when submitting this form (I assume it could be realized as execute another REST endpoint from REST endpoint with my custom form).
At the moment I am able to create only a link in project section (using custom web item) and execute custom REST endpoint (my custom form) as dialog ("run code and display a dialog") or as a simple link ("navigate to a link").
Is it correct way to create a custom report?
Is it possible to place my form inside Project->Reports section (or may be as new gadget)?
Fyodor
You can not create a report using Scriptrunner.
But I want to!
I want three!!
Sure you can, I do it all the time. What's preventing you to create a report?
And how do you do that?
Can you post a little example?
I am looking for a solution to get a report of all processed tasks of a user across projects.
Firstly, will your report need criteria. If yes you need to
Next you need to create a REST endpoint that takes the form input and generates the report. I normally generate an excel file using Apache POI
Register now
