Create customfield with multiple values- like a table
Dan27
I would like to create a customfield that looks like that:
aaa - 3
bbb - 3
ccc - 66
ddd - 18
eee - 2
I need to display all of those options in the view of the issue.
Maybe like a table? ot multiple cascading?
How can I do it?
Daniel
Nic Brough -Adaptavist-
August 30, 2020
It is not clear what you are looking for here.  You've described a set of lines of text as the goal, but then mentioned cascading select and tables.  Could you explain what you are looking for clearly?
Dan27
I would like to display those texts, but it a table tamplate or multipale cascading template.
August 31, 2020
Repeating part of your question is not explaining what you are looking for.
Dan27
An option to create a custom field that looks like table, that all of the values (rows and columns) will display in the view screen.
Or more clearly, a custom field that includes this data somehow (rows and columns in a table or other way):
aaa - 3
bbb - 3
ccc - 66
ddd - 18
eee - 2
August 31, 2020
Right so nothing to do with select lists.
You could use the simple table formatting in a rich text field natively, but for a proper table-as-a-field, I would reach for the table grid app.
