Need to "press a button" so everything on prod gets copied over to stage (one way). It's a terrible pain to test things when they're very out of sync.
Are you considering docker?
Check for instance the open-source atlassian docker builder
https://bitbucket.org/adockers/atlassian-docker-builder
Refreshing the test environment is pretty straightforward and it takes a couple of minutes ..
Register today
