Create issue directly from external database
Mehran Namdar August 16, 2018
Can i generate issue with jira from external database ?
I have old ticketing that working now and i want sync with old
Krishnanand Nayak
August 16, 2018
We used the CLI plugin from BobSwift to do it when were in transition phase. We built a listener that monitored the old system for updated and trigger the CLI commands to do they sync.
Mehran Namdar August 18, 2018
Sorry
But i'm beginner . Would you help me know how can do that ( step by step )
BR
Nic Brough -Adaptavist-
August 16, 2018
Yes, but you will need to write code.  Either some add-on for Jira that can read the database and create issues from it, or something outside Jira that can read the database and push issues in over the REST interface.
Thanks nic
But i cannot write code
August 18, 2018
The only way to do what you want to here is to find or write code to do it.
Register today
