Create issue in a Remote JIRA instance from another JIRA using REST API
amit raj
Hi ALL,
I am trying to create a JIRA issue from one JIRA instance to the other using JIRA API. I am using
groovy. This code works perfectly fine when I run it from intellijIDEA , when I run the same code in scriptrunner console, it doesnt throw any error and never creates the issue. could anyone help please.
I mean create issue in another remote JIRA instance from a local JIRA instance using
scriptrunner postfunction.
//code starts here-----------------------------------------------------
import groovy.json.StreamingJsonBuilder
def baseURL = "http://19.91.94.39:8080/rest/api/latest/issue";
def authString = "admin:*****".getBytes().encodeBase64().toString();
def body_req = [
"fields": [
"project":
"key": "AOBD"
"summary": "REST Test",
"issuetype": [
"name": "Task"
URL url = new URL(baseURL);
HttpURLConnection connection=(HttpURLConnection)url.openConnection();
connection.setRequestProperty( "Authorization", "Basic ${authString}" );
connection.requestMethod = "POST";
connection.doOutput = true;
connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8");
connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) }
connection.connect();
//code ends here------------------------------
Thank you
Niclas Sandstroem
March 11, 2017
You calling the wrong URL for REST API create issue to start with.
https://docs.atlassian.com/jira/REST/server/#api/2/issue
amit raj
Hi Niclas,
Thank you very much for your response.
I changed the URL from
http://19.91.94.39:8080/rest/api/latest/issue to "
http://19.91.94.39:8080/rest/api/2/issue
but it still doesnt work. Basically I replaced "latest" with "2" . is that correct?
Thank you
Niclas Sandstroem
March 12, 2017
You can find plenty of examples here. Make sure it works with cURL first.
https://developer.atlassian.com/jiradev/jira-apis/jira-rest-apis/jira-rest-api-tutorials/jira-rest-api-example-create-issue
Your payload seem to [] instead of expected {}.
Br, Niclas
adammarkham
March 13, 2017
In addition to what Niclas has said, if you have an application link setup between both you're best off using that. There's some examples of how to do that to intregrate between Atlassian application using ScriptRunnner here: https://scriptrunner.adaptavist.com/4.3.18/jira/interacting-with-other-apps.html
Rajesh_Ramankutty
February 15, 2022
Hi team can u give me this code for creating issue m trying to create issue from one jira to another using script runner
