Create issue is not setting post functions
Rai Warbasse October 26, 2018
I have read the other posts of this not working and they do not help.
I am trying to create an issue and have the resolution change to something other than "unresolved" and assign to a specific person. The same transitions are working in the rest of the workflow but not at the time of create.
My access is set to "create issue" and Jira-Admin
I have tried the property "jira.issue.editable = true"
The Workflow is assigned to the issue and is published
I'm running out of ideas....
Deleted user October 31, 2018
Hi @Rai Warbasse,
 You need to store issue post function for this to work. See this similar question .
Swathi
Rai Warbasse October 31, 2018
Your suggestion was spot on. Thanks so much
I found there may be an ordering need. I was attempting to Assign to a user and set the resolution. I found that the Set assignee needed to be before Create and Set the resolution needed to be after Set status and store update followed that. My post went as:
  1. Set assignee
  2. Create the issue
  3. Set issue status
  4. Set Resolution
  5. Store Update
  6. Re-index
  7. Fire issue created
Hope this helps.
Register today
