After clicking the "Create Issue" link, the "Create Issue" dialog appears and I fill out some fields and hit "Create."
DESIRED BEHAVIOR: The newly created issue ticket should be opened and displayed.
ACTUAL BEHAVIOR: Whatever window I was previously in is displayed again (along with a small banner reading "new issue successfully created").
The problem with the current behavior is that, more than once I've created a new issue and clicked Create, and then (wanting to update it immediately), pressed the Edit button and changed some fields mistakenly thinking that I was editing the new issue, when in fact I was editing the ticket that just happened to be have been displayed before I hit the Create Issue link.
Is there any way to customize the workflow, so that newly created tickets are automatically opened?
UPDATE: This appears to be a common complaint: Here's a duplicate question.
Hey Kevin,
Have a look at this page: https://confluence.atlassian.com/display/JIRA/Creating+an+Issue
There are some comments at the bottom, on how to customize a JS file to accomplish that.
Hope it helps.
looks promising (though more invasive than I'd hoped), but unfortunately I can't seem to get it to work. (My javascript skills are fairly rudimentary and I can't get any changes to have any effect).
I had to read through ALL the comments to find the solution, (and install Firefox plus Firebug), but eventually I got it to work for me. Thanks for the link!
UPDATE!! This feature is now available as a plugin: Issue Quick Start
works up through JIRA 7
thx!
@Darcy Stuart: Andrew Heald has released a new version of his Quick Start plugin. I have installed it on JIRA 7.0 and it works perfectly. Give it a try!
@Kevin Mote Thanks for the heads up! You've made our service desk team very happy.
@Darcy Stuart: Credit Andrew Heald. He worked on this all weekend (pro bono!)
Installed it on JIRA Software 7.1.7 and it mysteriously didn't work for the first two tries but it works now. It loads the new issue in about 1 sec after the fly-in notification dissapears. I am falling over with joy. Thanks to @Kevin Mote and even more thanks to @Andrew Heald!
Here's my final solution, for others who may need this: (tested on v.5.1.3)
create a new subfolder and javascript file on server: <tt>INSTALL\atlassian-jira\atlassian-jira\includes\js\custom\custom.js</tt>
jQuery(document).ready(function($){ if (JIRA && JIRA.Forms) { JIRA.Forms.UnconfigurableCreateIssueForm = JIRA.Forms.UnconfigurableCreateIssueForm.extend({ handleSubmitSuccess: function(A){ console.log(A); //A is the variable assigned to the asynchronous action's response if (this.helper.getCreateAnotherCheckbox().is(":checked")) { this.helper.handleSubmitSuccess(A); } else { window.location = '/browse/' + A.issueKey;}}});}});
<script type="text/javascript" src="/includes/js/custom/custom.js"></script>
As I mentioned in my answer below, there is now a fantastic plugin that provides this functionality.
Help us plant more trees
