Create issue with Affects Version/s field using Rest API
Sravya Vuggina September 14, 2018
I am trying to create an issue using Rest API and affects version/s field is mandatory in our create issue screen.
"versions":[
                        "id":"15911"
Tried using the above mentioned syntax but I get this
error {"errorMessages":[],"errors":{"versions":"Version id '15911' is not valid"}}
The id I used is from projectversion table,is that the right id? Also tried with name instead of id and got similar error.
{"errorMessages":[],"errors":{"versions":"Version name 'Example 1.3.1.4' is not valid"}}
How can Affect Version/s value be set?
Mohamed Riza
September 17, 2018
Hi @Sravya Vuggina
Can you please run the REST API call GET /rest/api/2/project/{projectIdOrKey}/versions for the project you are trying to create the issue in and verify if the version ID is present for this project.
Sravya Vuggina September 17, 2018
Hello @Mohamed Riza,
Thanks for your response!
Ran the mentioned link to fetch the list of versions pertaining to the project I was working on and tried the same code - it worked! Earlier I was trying with a version of a different project. :)
Deepali Bagul
Hello @Mohamed Riza @Sravya Vuggina
Can you please guide me on how to set the affects version/s on Jira ticket using Rest api & json. I tried this "versions" : [{"name": "2022.0"}] but it doesn't work.FYI version 2022.0 is already added to the project. Below is the JSON I am using for Jira import.
{ "projects": [
{ "name": "VIEW",
  "key": "VEW",
  "issues": [
        "priority": "High",
          "status": "OPEN",
        "resolution": null,
        "issueType": "Defect",
        "summary": "[Documentation] = Extra arrow in help",
        "assignee": "dbagul",
        "versions:" : [{"name": "2022.0"}],
        "created": "2019-02-01T16:05:52.13Z",
        "updated": "2022-03-02T00:34:16.903Z",
        "reporter": "dbagul",
        "components": [ "Documentation" ],
        "description": "!img_desc_2992_0.png!\n\n",
        "comments": []
Using above json I always get the below error during import. I have also tried "versions:" : ["2022.0"] and "Affects Version/s:": [ "Active Projects" ] but none of it works
2022-05-05 23:25:32,704 ERROR - Failed to create data bean
java.lang.RuntimeException: org.codehaus.jackson.map.exc.UnrecognizedPropertyException: Unrecognized field "versions" (Class com.atlassian.jira.plugins.importer.external.beans.ExternalIssue), not marked as ignorable
 at [Source: java.io.StringReader@6e0b1a2f; line: 13, column: 25] (through reference chain: com.atlassian.jira.plugins.importer.external.beans.ExternalProject["issues"]->com.atlassian.jira.plugins.importer.external.beans.ExternalIssue["versions"])
Looking forward to hearing from you, thanks!
aliva dash July 5, 2022
how did this got resolved?
Deepali Bagul
@aliva dash Below JSON would work for the fix version and affected version as well. Hope this helps
{ "projects": [
{ "name": "VIEW",
  "key": "VEW",
  "versions": [
        "name": "Active Projects"
  "issues": [
        "priority": "High",
          "status": "OPEN",
        "resolution": null,
        "affectedVersions:" : ["name": "2022.0"],
        "comments": []
Register Now
