Create multi-level Cascading Select List with ScriptRunner
jessiexjqin August 31, 2020
Hello There,
I would like to use a multi-level cascading select lists with ScriptRunner.
There's the custom field type "Select List (cascading)" only supports 2 levels, and I want to 3 levels (and maybe more). I search in community that there is an add-on "Multi-Level Cascading Select" can full fill this, but is non-free. Does anyone try with ScriptRunner?
Nic Brough -Adaptavist-
August 31, 2020
Have a look through https://library.adaptavist.com/search?page=1&products=jira&term=select - there are loads of scripts there that could help you make fields interdependent.
James Webster
Hi @jessiexjqin ,
Did you find or create a script for the multi-level (more than the standard 2) cascade?
James
chinmay borkar January 12, 2022
Hi @jessiexjqin and @James Webster  did you get the solution for this condition.
James Webster
Hi @chinmay borkar ,
I managed to work out a custom script in the end which I set up as a behavior.
You need an initialiser first (replace the bits in bold) -
def optionsManager = ComponentAccessor.getOptionsManager()
def customField1 = getFieldByName('******Field name 1******')
def customField1Value = customField1.getValue()
def customField2 = getFieldByName('******Field name 2******')
def CustomField2CF = customFieldManager.getCustomFieldObjectsByName("******Field name 2******")[0]
def config = CustomField2CF.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
switch(customField1Value){
case '****Field 1 drop down value A****':
def newOptions = options.findAll { it.value in ["***Field 2 drop down value A***", "***Field 2 drop down value B***", "***Field 2 drop down value C***"] }
customField2.setFieldOptions(newOptions)
break;
case '****Field 1 drop down value B****':
def newOptions = options.findAll { it.value in ["***Field 2 drop down value D***", "***Field 2 drop down value E***"] }
break;
case '****Field 1 drop down value C****':
def newOptions = options.findAll { it.value in ["***Field 2 drop down value F***", "***Field 2 drop down value G***"] }
break;
Then you add the serverside scripts with the Field 1 script the same as above and then the subsequent field scripts updated reference the relevant data sets is -
Field 1 Server-side script covers Fields 1 + Field 2
Field 2 Server-side script covers Fields 2 + Field 3
Field 3 Server-side script covers Fields 2 + Field 4
and so on....
Hope that helps...
James
Like • 2 people like this
