Hi ,
When i searched regarding the scheduled task in JIRA, i found the below link about scheduled task with sample example . it was perfect example , but still i have some queries on that .
http://www.j-tricks.com/tutorials/scheduled-tasks-in-jira
The below is the folder structure created in that sample example package:
scheduled-task-plugin\pom.xml
scheduled-task-plugin\src\main\java\com\jtricks\JTricksScheduledJob.java
1,How to build Jar for this above example .
2,what is purpose of having pom.xml.
pom.xml:
<?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>com.jtricks</groupId> <artifactId>scheduled-task-plugin</artifactId> <version>1.0</version> <organization> <name>J Tricks</name> <url>http://www.j-tricks.com/</url> </organization> <name>scheduled-task-plugin</name> <description>This is the Example com.jtricks:scheduled-task-plugin plugin for Atlassian JIRA.</description> <packaging>atlassian-plugin</packaging> <dependencies> <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>atlassian-jira</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.6</version> <scope>test</scope> </dependency> <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-func-tests</artifactId> <version>${jira.version}</version> <scope>test</scope> </dependency> </dependencies> <build> <plugins> <plugin> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-jira-plugin</artifactId> <version>3.0.6</version> <extensions>true</extensions> <configuration> <productVersion>${jira.version}</productVersion> <productDataVersion>${jira.data.version}</productDataVersion> </configuration> </plugin> <plugin> <artifactId>maven-compiler-plugin</artifactId> <configuration> <source>1.5</source> <target>1.5</target> </configuration> </plugin> </plugins> </build> <properties> <jira.version>4.0.2</jira.version> <jira.data.version>4.0</jira.data.version> </properties> </project>
You don't really need a pom for this. You can create the jar from eclipse or simply by packaging the files. In this case, pom was added just to make it easy to build the jar and also to start a JIRA instance for testing
Btw, you might also want to look at this tutorial. Involves a little bit more work up front but then you don't have to modify the scheduler-config.
Hello i am using the same tutorial for my scheduler,
http://www.j-tricks.com/1/post/2011/05/scheduled-tasks-in-jira.html
Now I need to run it one of it every Midnight, one every Monday and one to every Month end . how we can set the scheduler interval to 1 week. or one month I want my scheduler to run every Monday or every month end .
please give me some suggestion on how we can set the scheduler interval to 1 week or end of the month .
