Create subtask with scriptrunner: setting assignee
Julian Radünz February 9, 2014
I'm using "Create sub-task" post function when creating issues. Unfortunately the script always sets the assignee of the subtasks to the parent's assignee.
I want to set it to a "hard-coded" specific user (no role member etc.).
My sub-task is using an own workflow, but "Update field value" / Assignee = <User> is not working although it's located after "Create issue" post function.
Any ideas how to do it?
3 votes
Tsol
February 9, 2014
Use the following in additional issue actions box
issue.assigneeId = "username"
Julian Radünz February 10, 2014
That was easier than expected. Thanks!
Alark Patel June 22, 2016
This was simply the easiest way to do this. Thanks @Kostas Tsolakos. I was hope less in finding the easier way.
