Hi
I'm trying to create a User from script, but I want to turn off the mail nofitication when a user is created. This is my code:
//Defino los parametros necesarios para crear un usuario
UserService userService = ComponentAccessor.getComponent(UserService);
//CreateUserRequest nos sirve para saber si se puede crear susodicho usuario
UserService.CreateUserRequest createUserRequest = UserService.CreateUserRequest.withUserDetails(creator, username, password, emailAddress, displayName);
createUserRequest.sendNotification(false);
UserService.CreateUserValidationResult result =userService.validateCreateUser(createUserRequest);
after this I do:
log.info("Result is valid");
def newUser = userService.createUser(result);
log.info("User created");
Then I set a few groups for this user.
My problem is the users are reciving the notification of new user created but I'm using createUserRequest.sendNotification(false);
I think the issue is that method createUserRequest.sendNotification(false) returns you new createUserRequest instead of updating old, so you should either do
createUserRequest = createUserRequest.sendNotification(false)
or when creating it altogether
UserService.CreateUserRequest createUserRequest = UserService.CreateUserRequest.withUserDetails(creator, username, password, emailAddress, displayName).sendNotification(false)
Thanks, I used the second option and now isn't sending notifications to the new users.
