I am using the "Create on Transition Plugin for JIRA".
I want to create 20 subtasks for 1 parent. The subtasks will contain the same Summary but 1 change on each summary.
For example:
The parent Summary is: "Testing the applications"
and all the 20 subtasks to this Parent will have the title:
"Testing the applications - Application1"
"Testing the applications - Application2"
"Testing the applications - Application20"
I assume I need to start the Summary with %parent_summary%
but how to I pass for each subtask a different application name?
You have the right idea. Set summary to: %parent_summary% - %entry%
and configure the Create multiple issues field with
Application1,Application2,Application3, ... ,Application20
%entry% gets replaced with each value from the comma separated list of values as each issue is created. References are:
