×Hello,
we are trying to automate our JIRA / Confluence workflow. (DataCenter)
Services to be automated:
1. Copy an existing JIRA template and create a new project
2. create a new Comfluence Space
etc.
as we use ENTRA Groups for permission management, the same groovy script has to trigger a powershell script and forward some variable to it.
This 2nd Powershell Script has to connect via MS Graph and create the groups.
I think with this script we can make execute the PS-Script at the and of the Groovy Script.
def issueKey = issue.key
def customFieldValue = issue.getCustomFieldValue(customField)
def command = "powershell.exe -ExecutionPolicy Bypass -File
C:\\Scripts\\meinSkript.ps1 ${issueKey} '${customFieldValue}'"
def process = command.execute()
process.waitFor()
def output = process.text
log.info("PowerShell Output: $output")
Question:
Is is technically a viable way to work or are there better options to create groups - via Scriptrunner for JIRA - in M$ ENTRA?
Best regards
Atlassianist.
//Sorry, we are working on DataCenter. The Category of the thread is not correct//
