×Hi,
I am trying to create a subtask for the issue Type but in a particular Project.
I tried following the manual for the same and following are steps I got from it.
Creating a sub-task
1.Navigate to the issue which you would like to be the parent issue of the sub-task you are about to create.
2.Select 'Create sub-task' from the 'More Actions
' drop-down menu.
Can someone please tell me to which link(option) should I navigate after selecting the Administration tab to do step1.
-Athira
To enable sub-tasks in Jira :
Administaration -> Issue types -> Sub-Tasks
To create a sub-tasks : ( Not in adminstaration )
Open the issue -> More Actions -> Create sub-task
