Creating a Table view using column values off another column
Andrew Bui
February 19, 2025
I'm looking to output a display via our rich filter dashboard that requires a column that displays a field from another column, that is not the key.
I have the following data structure:
ProjectB-123
is unique related to:
ProjectA-456
and ProjectA-456 has versions = 1.0.0, 1.0.1, 1.0.2
My table should be:
ProjectB-123 | ProjectA-456 | 1.0.0, 1.0.1, 1.0.2
I'm having trouble getting the second column in jira rich filters, but was able to get it in jxl. In my rich filter dashboard, I can only show "all linked issues". I cannot seem to get the third column which is a field based off of the "linkedissue" column.
I'm open to exploring jxl and potentially eazyBI. Thank you!
Marita Burgio February 24, 2025
Hi @Andrew Bui
If Project A and Project B are Issues in Jira that are linked using issue links, you can create a report showing the linked issues and their fix versions in eazyBI. Here's how:
This report shows which Issues (column 1) are blocking other issues (column 2) and what are the respective fix versions.
If this is not how it's structured in your instance, feel free to reach out to support@eazybi.com to describe your use case & we will be happy to help.
Best,
Marita from eazyBI support
