Is there a way to create a customized issue navigator screen for different projects? Can you choose a default "view" or screen to be seen when the project is chosen?
Hi Cherie,
you could provide for every project a separate Dashboard with only one Dashlet of type "Filter Results" (default; built into Jira) or - much more flexible - use the "Column Order Gadget Plugin".
The "Filter result" dashlet shows columns in ASCI order A-Za-z; where as the "Column Order Dashlet Plugin" allows arbitrary column orders.
BR, Markus
