I'm trying to create an issue using the REST API. I've looked through several examples and videos and cannot find what I could be doing wrong. I keep recieving a 400 Bad Request error...
I'm running the following method:
http://localnet:8080/rest/api/2/issue/
This is my code:
"fields": {
"project": {
"key": "TP"
"summary": "TEST API",
"description": "Test Description",
"issuetype": {
"name": "Task"
This is what I recieve back:
"errorMessages": [],
"errors": {
"project": "project is required"
Community moderators have prevented the ability to post new answers.
Hey all,
In order to make sure the Community sees additional questions you might have about errors like this (which may have varying causes), please ask a new question here on the Community so we can help you individually and ensure that your question is viewed by users actively looking to answer new questions.
You can use this link to quickly ask a new Jira question.
Daniel | Atlassian Staff
I'll provide source code later, however, please see what I've done here : https://stackoverflow.com/a/59981597/1551368
Your JSON looks ok, so I suspect that either project TP does not exist or the user you are logging in with does not have permission to create issues in it.
I am seeing the same issue. My json is find and I have a valid project key but still shows me the same error. What are all of the possible reasons for this error?
Hi Pavani, am facing the same issue as well, did you figure it out what was causing the issue? If so please let me know.
Hi, I also facing the same problem please let me know how to resolve this problem.
Help us plant more trees
