Creating notifications for specific field updates
LakshmiS
How can I create an email notification when a specific field - say Estimate / Story points is changed?
Also, when a new story is added to an epic
JamieA
June 26, 2014
You can fire a custom event in a listener if the filed changes - see https://jamieechlin.atlassian.net/wiki/display/GRV/Built-in%20Scripts#Built-InScripts-Firesaneventwhenconditionistrue
You then hook that event to a velocity template if you want to use velocity.
If you don't want to use velocity you can write your own email template: https://jamieechlin.atlassian.net/wiki/display/GRV/Built-in%20Scripts#Built-InScripts-Sendacustomemail
Other methods from other plugins are probably available.
LakshmiS
I see that Script runner is not available for Ondemand which is what I an running . https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Is there a work around?
JamieA
June 26, 2014
Well maybe you could tag your question correctly then you will get better targeted responses.
