try with this code(i have used in java), do changes as per your requirement
Issue issue = (Issue) transientVars.get("issue"); for(int i=1;i<=5;i++){ createSubtask(issue); } public void createSubtask(Issue sIssue) { MutableIssue mutableIssue =ComponentAccessor.getIssueFactory().getIssue(); mutableIssue.setDescription("Test"); IssueType issueType = IssueCustomFieldConstants.constantsManager.getIssueTypeObject(3);//enter subtask issue type id as int mutableIssue.setIssueTypeObject(issueType); mutableIssue.setPriorityId(3); mutableIssue.setSummary("summary"); mutableIssue.setProjectObject(sIssue.getProjectObject()); mutableIssue.setReporter(sIssue.getReporter()); mutableIssue.setAssignee(sIssue.getReporter()); Map<String, Object> params = new HashMap<String, Object>(); params.put("issue", mutableIssue); final JiraAuthenticationContext authenticationContext = ComponentAccessor.getJiraAuthenticationContext(); User currentUser = authenticationContext.getLoggedInUser(); try { IssueManager issueManager = ComponentAccessor.getIssueManager(); Issue issue = issueManager.createIssueObject(currentUser, params); SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager(); boolean isSubtaskEnabled = subTaskManager.isSubTasksEnabled(); subTaskManager.enableSubTasks(); subTaskManager.createSubTaskIssueLink(sourceIssue, issue, currentUser); if (!isSubtaskEnabled) { subTaskManager.disableSubTasks(); } } catch (CreateException e) { e.printStackTrace(); } }
