Oftentimes I find myself in need of creating a story and a set of standard subtasks like "Write SRS section", "Peer review design", "Create unit tests", "Run integration tests", "Create story report", etc
I would very appreaciate a feature that would allow me to pick a story template and automatically create the subtasks.
I found this old issue where a solution is offered to exact same question: https://answers.atlassian.com/questions/25049/jira-creating-sub-tasks-automatically-based-on-a-template
However that one was almost 2 years ago, I bet Jira had gotten better since.
Which is the best way to auto-populate story with subtasks?
Community moderators have prevented the ability to post new answers.
And I have finally found a plugin that does exactly what I need:
https://marketplace.atlassian.com/plugins/com.hascode.plugin.jira-quick-subtasks
Simple and straightforward, minumum intrusion. Highly recommended.
In case if someone else is searching, another way I found useful is creating a model task with subtasks and cloning it each time you are creating a new task you need templated.
This is the link
https://marketplace.atlassian.com/plugins/org.swift.jira.cot
it's really a nice plugin, all of that could be done with scripting (with script runner) but that plugin helps administrators and it's well made.
Frankly, this https://dq1dnt4af4eyy.cloudfront.net/files/org.swift.jira.cot/screenshots/96dfd834-1384-4317-a11d-4cf407ca71d5.png
looks really intimidating. Maybe, I'll try it, though :)
Yes, it can be :). Just use the minimum you need for your use case and know that there are some more advanced capabilities when the need arises.
Hi @Nicole Downes love it! Do you happen to have an Excel you can share. It will save ages to me so thanks in advance for that.
Can't find a place to load a file, so here is a screen shoot. Give me your email address and I will happily send you the file.
Important tips:
thank you so much for the head start. I got the idea I will start working on my own.
Thanks for all the tips too ;)
For those of you that cannot/not permitted to have all the suggested plug-ins, the simplest way is to construct an import file in excel in csv format and import the file. I have used this many times to create the epics, stories and sub-tasks all at the same time. You can include assignee, estimates, story points, description and whatever else you need in the file. Only restriction is to create linked items (such as sub-tasks), you need to be a system administrator to have import permission.
I keep the file in Confluence. Then I use excel's file and replace to change the epic names and other information that may be project, client, or environment specific.
This solution is not as fancy as others, but it gets the job done.
https://confluence.atlassian.com/adminjiracloud/importing-data-from-csv-776636762.html
Hi @Nicole Downes - Is this method applicable for JIRA Server of for JIRA Cloud only?
Can you please send me the sample excel/csv file please at <markalvin.francisco@safeway.com>. Thank you.
Consider using Create On Transition for JIRA.
I think you've posted the wrong link - it leads to "What happened to..." page
Thanks for pointing that out. I copied a really old link. It is updated now.
