We are using JIRA v6.3.15 on a private cloud environment and have a need to display release cumulative flow for a release (Fix version) in dashboard. When we search, there's no readily available gadget in JIRA, please help to achieve this.
Please, how can i include this report at panel dashboard?
Hello Anish,
On Jira/Agile 6.3, you should have the Agile Classic Cumulative Flow Chart Gadget available to use on your Dashboard, which uses the Fix Version as one of the configuration options for defining the output of the gadget.
please check this out and let us know if this is what you were looking for.
Earl
We also have this same need using version 8. there is no Cumulative flow chart gadget
Hi @Robert Kirkman ,
We are tracking the creation of a gadget for the "Cumulative flow chart" at the following Feature request, noting from the description that it was originally created for supporting sprints in the classic gadget but morphed into Creating a gadget once the classic gadget went away:
Also another note on this, per the Implementation of New Features Policy, is that it is currently not in the roadmap but is flagged for review which should be sometime soon as the note in the description was posted in October last year stating:
Thanks for your interest in this issue. This suggestion is considered a potential addition to our longer-term roadmap. We'll typically review this request in about 12 months time, at which point we’ll consider whether we need to alter its status.
So I would recomend adding yourself as a watcher to the request so you will receive an email when the request is updated, also make sure to add your vote to help track contended interest in the feature.
Earl
