Sign up Log in
Custom Field file - server side
Marco Colageo
Hi all,
Which is the JIRA server-side file that contains the Custom Field definitions?
Marco
Nic Brough -Adaptavist-
May 27, 2013
That's not really a question we can answer, it's a bit too vague.
You might mean "which jar/class/vm/etc files define how a custom field type works", or "when I add a custom field and name it Fred, where does that get stored?". In the first case, you'll need to tell us what you're looking for in more detail. In the second case, the answer is "there is no file, it's in the database".
Marco Colageo
Hi, I've got the point. I need to delete the definition of a custom field whose description contains js and html. That js/html code is causing problems with the Custom Field page in the administration section ( the cog icon does not work more!!!).
Cheers
May 27, 2013
Ok, you don't mean "files" then. The definition of a custom field is held in the database, and you'll need to amend that directly.
You could render your Jira completely unusable if you get any SQL wrong, and I certainly wouldn't try to delete a custom field with SQL.
What I would do is
  • Backup your database
  • Stop Jira
  • Use SQL to amend the description of the field to something like "please remove me"
  • Restart Jira
Note that steps 1 and 2 really are mandatory. Never use SQL on a running Jira, and never run SQL against Jira without a backup...
That will make the cogs work, won't lose you any data and will let you continue working with the field (including deleting it if you're sure you don't want it any more).
From memory, your SQL needs to amend the table "customfield"
Timothy
May 27, 2013
You are looking for this folder.
atlassian-jira/WEB-INF/classes/templates/plugins/fields
Timothy
May 27, 2013
