I am trying to set a custom field with automation. I can log
the {{triggerissue.customfield_14651}} and get the right answer before I go into "For Linked Issues: Split To" ir even inside of the loop. However, when I try to set it via JSON or even manually I get an error like the one in the title.
Here is my JSON:
"fields": {
"customfield_14651": "{{triggerissue.customfield_14651}}"
This works fine when I create sub-tasks, but for some reason, when I try to set a "split story" custom field, it just doesn't work. I have tried many permutations including json object, toString, hard coded strings (that are valid) etc. Nothing seems to work except when I hard code the number for the string (e.g. "86" which relates to "xxx xxx xxx"). I can't seem to figure out how to retrieve the number using smartvalues, so I am asking the community if any of you have any ideas on how to get it, or how to make it work using the JSON.
Here is one of the ways I implement it and log some stuff to validate it has data:
Dan
