Custom Field to Link Issues
simon roberts
Hi
Is there a custom field to link isses at time of entering in the details of a bug, rather than have to do if from the view screen?
Simon
3 votes
Fernando Llaca Romero
Hi ,
You can try a free plugin I've made: Easy Links for JIRA. It provides two new custom field types: Single Issue Link Picker and Multiple Issue Link Picker. These custom fields are displayed as dropdown select lists, which you can filter and autocomplete by typing on it (see screenshots). Also, you can configure the customfields to restrict the available issues to select (using a JQL expression when creating the custom field), and the link type that the field will be associated to. When you select a value, a new issue link is created between the current issue and the selected one(s), that you can manage as a regular issue link.
In addition, you can use the custom field in JQL queries (for example: "Blocking Task" = TEST-123), and in dashboard gadgets (pie charts, filters, etc).
I hope it can solve your issue,
greetings!
Edward Garay
February 16, 2017
HI Fernando,
This looks like a very useful plugin. Does it work on JIRA 6.4 ?
Best Wishes
Hi Edward,
at this moment it is only available for 7.x.x, sorry sad
Regards
Kavitha Yeleti February 21, 2018
Hi Fernando,
Is this plugin(Easy links for JIRA) compatible with JIRA Core(7.xx) Server?, as i could see its compatible with JIRA Service desk application only.
Is it okay to add that plugin via upload add-on button?
Kavitha
Vinu
December 20, 2018
Hi Kavitha
We are using this plugin for Jira software and it works just fine. I see no reason on why it should not work on core.
JBennett
Hi Fernando. We have been using your easylinks addon for about 12 months and its been great. However it no longer works in JIRA 8.0.2 and we have it on a few of our issue forms. This is preventing users from creating these issues and we are not sure what to do.
Can you help. Many thanks
Jon
Alex Harding March 13, 2019
I'm super keen to see this work in 8 too
Like • Neil Taylor likes this
Pavel Stržínek
April 2, 2019
No, it does not work on 8.0.2, unfortunately.
Neil Taylor
+1 for having this upgraded for Jira 8 - this is a fantastic addon - we would definitely still be interested if it was paid as well.  Currently it is holding up our upgrade to v8.  Are there any plans to upgrade it or does anyone know of any similar alternatives?
Like • Gautham likes this
Antônio Duarte
+1. We also need it!
There is no mention to this app anymore on Marketplace!
The nearest I found was https://marketplace.atlassian.com/apps/1220571/custom-fields-issue-picker?hosting=server&tab=overview, a paid one!
I'm looking forward for a reply from the author of Easy Links for JIRA...
Dario B
June 11, 2020
The app is still available in the marketplace and it supports Jira Server 8.x:
Nathaniel Elliott
Will you be building this for Cloud?
Nathan Packard June 19, 2020
I second that, having this on cloud would be really great.
JamieA
November 8, 2011
You can add the "Issue links" (or some similar name) field to the create screen, providing you are on jira 4.4 onwards.
sachdera
March 2, 2017
It is throwing the following exception for version 6.4.13. Please help.
2017-03-03 18:44:02,874 UpmAsynchronousTaskManager:thread-1 INFO admin 877x2185x3 qqibm8 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [atlassian.plugin.loaders.ScanningPluginLoader] No plugins found to be installed
2017-03-03 18:44:02,874 UpmAsynchronousTaskManager:thread-1 INFO admin 877x2185x3 qqibm8 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [atlassian.plugin.manager.PluginEnabler] Resolving 0 plugins
2017-03-03 18:44:02,874 UpmAsynchronousTaskManager:thread-1 INFO admin 877x2185x3 qqibm8 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [atlassian.plugin.manager.PluginEnabler] Enabling 0 plugins: []
2017-03-03 18:44:03,214 UpmAsynchronousTaskManager:thread-1 ERROR admin 877x2185x3 qqibm8 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [atlassian.plugin.loaders.ScanningPluginLoader] Unable to deploy plugin 'com.codedpoetry.easylinks.easy-links' from 'Unit: /Users/ranjusachdeva/myPlugin/amps-standalone-jira-6.4.13/target/jira/home/plugins/installed-plugins/plugin_8541425109212871393_easy-links-1.1.3.jar (1488527042000)'.
2017-03-03 18:44:03,214 UpmAsynchronousTaskManager:thread-1 ERROR admin 877x2185x3 qqibm8 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [atlassian.plugin.loaders.ScanningPluginLoader] Because of the following exception:
com.atlassian.plugin.PluginParseException: Unable to scan for host components in plugin classes
 at com.atlassian.plugin.osgi.factory.transform.stage.HostComponentSpringStage.execute(HostComponentSpringStage.java:62)
 at com.atlassian.plugin.osgi.factory.transform.DefaultPluginTransformer.transform(DefaultPluginTransformer.java:146)
 at com.atlassian.plugin.osgi.factory.OsgiPluginFactory.createOsgiPluginJar(OsgiPluginFactory.java:324)
 at com.atlassian.plugin.osgi.factory.OsgiPluginFactory.create(OsgiPluginFactory.java:229)
 at com.atlassian.jira.plugin.MasterPluginFactory.create(MasterPluginFactory.java:81)
 at com.atlassian.plugin.loaders.ScanningPluginLoader.deployPluginFromUnit(ScanningPluginLoader.java:155)
 at com.atlassian.plugin.loaders.ScanningPluginLoader.loadFoundPlugins(ScanningPluginLoader.java:117)
 at com.atlassian.plugin.loaders.PermissionCheckingPluginLoader.loadFoundPlugins(PermissionCheckingPluginLoader.java:30)
 at com.atlassian.plugin.manager.DefaultPluginManager.scanForNewPlugins(DefaultPluginManager.java:850)
 at com.atlassian.plugin.manager.DefaultPluginManager.installPlugins(DefaultPluginManager.java:799)
 at com.atlassian.jira.plugin.JiraPluginManager.installPlugins(JiraPluginManager.java:163)  <+3> (NativeMethodAccessorImpl.java:62) (DelegatingMethodAccessorImpl.java:43)
 at java.lang.reflect.Method.invoke(Method.java:498)
 at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:134)
 at com.sun.proxy.$Proxy319.installPlugins(Unknown Source)  <+3> (NativeMethodAccessorImpl.java:62) (DelegatingMethodAccessorImpl.java:43)
 at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
 at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
 at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
 at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
 at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
 at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
 at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
