Is it possible to create a custom field which will allow to upload several images and zip files?
if yes, what is the procedure?
Thank you.
As far as I understand you need a custom attachment field. It is not possible to add custom attachment fields by default in Jira. You can use additional add-ons or write your own plugin in order to do that.
Regards.
Thank you for your answer. Could you please provide me the name of the add-ons that allows to upload attachments?
I have never personally used an add-on for this purpose but I found these two that could help. First one seems to do what you need. Second one, I'm not so sure but people recommended before.
https://marketplace.atlassian.com/apps/1217971/apwide-file-field?hosting=server&tab=overview
https://marketplace.atlassian.com/apps/1212507/smart-attachments?hosting=server&tab=overview
Hope this helps.
Register now
