Custom Fields (including Resolution) not visible in Field Configuration Schemes
JD September 2, 2020 edited
Certain Custom Fields (CF), whether they be user-created or system generated (i.e. Resolution is one that is impacted by the this issue), are not visible/do not show up in the list of CFs in any of the Field Configuration Schemes for projects.
However, I have re-named of one of the CFs and it has now appeared in the Field Configuration Scheme for the project.
This is not a situation where CFs are not being displayed, this is a situation where CFs, that can be seen/edited via the Custom Fields section under Administration, are not showing up in Field Configuration Schemes.
Also, a full re-index was performed.
Bhushan Nagaraj
September 2, 2020
Hey JD,
Strange. I suggest doing a full re-index of the instance. If this doesn't solve it, please raise a support ticket and our team can investigate it for you.
Running a manual re-index from Administration > System > Indexing
Bhushan
Thanks, that was already tried.  Sorry about not putting the info in the OP.
Bhushan Nagaraj
September 2, 2020
1. Are you able to see the user created custom field in <jira_url>/secure/admin/ViewCustomFields.jspa?
2. If yes, are you then able to see it in any of the field configurations on your instance at <jiral_url>/secure/admin/ViewFieldLayouts.jspa
Re #1: Yes, however the Resolution CF is not visible; not sure if it is normally visible.
Re #2: The Field Configurations are not showing any CFs that begin with the letter I/i all the way through to the CFs beginning with non-letter characters.
Bhushan Nagaraj
September 2, 2020
Re #1: That is expected behaviour. It only shows user created fields.
Re #2: You can either try troubleshooting this further by looking at the application logs, or raise a support ticket with Atlassian.
Nic Brough -Adaptavist-
September 2, 2020
A field configuration lists all fields that can be configured.  The fields may not have the right context, they may be hidden by permissions, and the screens they are on are totally irrelevant, so there's nothing that stops a configurable field appearing.
Could you show us a field configuration where you think fields are missing?
Thanks.  The fields are not hidden by permissions, also it has occurred with newly created CFs.   I don't think fields are missing, I know they are.  There are literally dozens of CFs that are not visible in multiple Field Configuration Schemes.  I can show you an example, but I'm not sure what good it will do - what are you looking for, if I might ask?
September 2, 2020
Just a view of a field configuration that seems to be missing fields.  Note - not a field configuration scheme, just a single field configuration.
Read the story
