Custom JQL Function Not Accepting Null Operand
Bellina Bui April 11, 2023
Overview
Hello Atlassian Community! I'm trying to build a custom JQL function that'll allow the subquery to pass as empty OR run the subquery (operand) that is defined by the user.
Example:
issueFunction in ademoTest()
issueFunction in ademoTest("reporter = name")
So far I got the script to work where users do not have to enter a subquery.
private com.atlassian.query.Query mergeQuery(FunctionOperand operand) {
def queryStr = MessageFormat.format(TEMPLATE_QUERY, "")
queryParser.parseQuery(queryStr)
Problem
However, if I add an if/else statement to allow the subquery to pass as empty OR run a subquery, it does not work. By not work, I mean that it'll require users to query
issueFunction in admoTest("")
//Instead of querying the below, which is a better user experience
My If/Else Statement is below.
Any help is appreciated :)
def queryStr = MessageFormat.format(TEMPLATE_QUERY, operand.args.first())
def queryStrEmpty = MessageFormat.format(TEMPLATE_QUERY, "")
if (operand != null){
} else {
queryParser.parseQuery(queryStrEmpty)
Code
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.jql.query.LuceneQueryBuilder
import com.atlassian.jira.jql.query.QueryCreationContext
import com.atlassian.jira.jql.validator.NumberOfArgumentsValidator
import com.atlassian.jira.util.MessageSet
import com.atlassian.query.clause.TerminalClause
import com.atlassian.query.operand.FunctionOperand
import org.apache.lucene.search.Query
import java.text.MessageFormat
class JqlAliasFunction extends AbstractScriptedJqlFunction implements JqlQueryFunction {
* Modify this query as appropriate.
* See {@link java.text.MessageFormat} for details
public static final String TEMPLATE_QUERY =
"project = ADEMO OR project = AWOLBP AND type = Task" // the scope of the query. To use a variable, pass it as {0}
def queryParser = ComponentAccessor.getComponent(JqlQueryParser)
def luceneQueryBuilder = ComponentAccessor.getComponent(LuceneQueryBuilder)
def searchService = ComponentAccessor.getComponent(SearchService)
@Override
String getDescription() {
"Pull in ADEMO and AWOLBP Tasks" // The text that appears next to the value defined in getFunctionName()
@Override
MessageSet validate(ApplicationUser user, FunctionOperand operand, TerminalClause terminalClause) {
def messageSet = new NumberOfArgumentsValidator(0, 1, getI18n()).validate(operand)
if (messageSet.hasAnyErrors()) {
return messageSet
def query = mergeQuery(operand)
messageSet = searchService.validateQuery(user, query)
messageSet
@Override
List<Map> getArguments() {
description: "Enter Subquery Here",
optional : true,
@Override
String getFunctionName() {
"ademoTest" // this is the named function in the query
@Override
Query getQuery(QueryCreationContext queryCreationContext, FunctionOperand operand, TerminalClause terminalClause) {
luceneQueryBuilder.createLuceneQuery(queryCreationContext, query.whereClause)
} else {
Aron Gombas _Midori_
def queryStr = MessageFormat.format(TEMPLATE_QUERY, operand.args.first()) // <-- in this line, you assume that operand is not null!
if (operand != null){ // <-- here you expect operand be legally null
} else {
Without looking very deeply into your code, I can see at least one problem. In the first line you implicitly expect that operand is not null, because you call a method on it.
Then in the "if", you test whether it is null, meaning that you expect it can be null.
The two are conflicting!
Bellina Bui April 27, 2023
@Aron Gombas _Midori_ Correct operand is not null, meaning users can enter in a sub-query.
Such as issueFunction in platformPG("insert operand")
However, if users do not enter a sub-query they can still run the JQL
issueFunction in platformPG()
So if it's not null parse the queryStr with the operand and if it's null parse it without it :)
Let me know if I'm misunderstanding your point! thank you!
@Bellina Bui
If you say that operand can be legally null, then:
should rather be:
def queryStr = MessageFormat.format(TEMPLATE_QUERY, operand ? operand.args.first() : "")
Can you follow me?
Jared Kells
You might have more luck in the developer community: https://community.developer.atlassian.com/c/jira/jira-server/8
Bellina Bui April 17, 2023
Thank you Jared!
